跳转到主内容
许多佳能数码相机和胶片相机的修理和拆卸指南。
1796 个问题 查看全部
问题已关闭
opening and cleaning a compact camera
hi, I have a canon PowerShot G7 and I've noticed that the sensor is dirty, the thing is my SLR cameras are easy to clean but the G7 has a closed body. So if someone can help with a sort of manual to do that I'll be a very very thankful guy.
awesome site!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
thanks a lot markus! I'll post if I'll achieve good results
完成的
ok, and if somethig goes wrong - like scratching the ir filter - "convert" it to a IR camera - the G models are perfect for that ;-)
完成的
Is this that simple? I mean getting of the IR filter will "convert" the camera to an IR one?
完成的
yes - it is
but there are a few more things you will need
first of all:
howto clean it or getting the filter out
the next step is getting two filters and the conversion tube for the g7
the filter conversion tube will cost less than 10$ on ebay,you will need a hoya r72 ir filter - the wavelenght is 720nm and you will be able to have color in your pictures (picture search for hoya r72)
the nex filter you will need is a ir filter (in case you want ever go back with normal colored pictures with this camera)
here are a few ir samples
完成的
添加一条评论
1个答案
已选择的解决方案
HERE is a estonian page with the teardown of a g7 - i linked it through the google translation - so i hope that you understand what they are writing
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,574
