跳转到主内容
Keyboard and touchpad with strange behaviour
Hi,
I'm posting here as I've a small problem with a macbook of a friend. The keyboard has a strange behaviour (wrong letters for keys, and of course it's not a language settings problem). I suppose it's a water problem but the touchpad has problems too.
When you move your finger on touchpad top left corner, the touchpad stops working for 2-3 seconds and then works again. I suppose it's a water problem too but how can I check if I have to change both keyboard and touchpad or mother board ? Do you think it could be the motherboard or the keyboard would always take the water first?
I've also read that some people found keyboards on ebay to avoid an all top case replacement. Is it trustable? Do anyone know a good ebay seller?
Thanks in advance !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Since you have problems with both the keyboard and touchpad the simple DIY solution would be to replace the top case.
A more complex and time consuming one would be to replace the individual parts keyboard and touchpad. Get the proper tools (every job is easier when you have the right tools)- read over the guides - make a decision.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for your answer, it confirms my diagnostic. I'll change the top case and touchpad then.
Thanks again.
完成的
添加一条评论
添加你的答案
Gilles Fernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 263
