跳转到主内容
加入维修社区 - 创建账户
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
Power button didn't work at first, now the MacBook shuts down
Hello,
2 weeks ago the power button on my laptop died. I turned it on with the power pads and it worked great as usual for 2 weeks.
Yesterday i returned home to find it shutdown and not able to start from the power pads. I got the chime and the screen with the apple logo and the rotating wheel underneath but it shutdown afterwards.
I cleared the ram, tried to boot from cd and recovery disk and it stayed with me until the installation step.
When i booted pressing T it got to the login screen but shut after i typed my password.
I am sure that there HASN'T been any liquid damage to my laptop and i don't understand why all these problem suddenly occurred.
Only solution i haven't tried yet is single user mode with fsck -fy.
I am curious why it could be a logicboard problem as it worked great as usual before. Could it be related to the small round battery on the logicboard next to the rams?
This site has been very helpful so far, thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
At that age it could be the battery - though generally that doesn't prevent a boot - just loses all the personal preferences (date, time, screen res. etc).
Logic board jump starting is not a fix - it's a diagnostic step. It is possible to damage the machine by force starting it. You could have moisture corrosion without an actual spill by working in a high humidity environment.
The command line really is just a HFS volume check - to detect directory/file errors... this is a software not hardware fix, in other words what fsck -fy does is not a reason for a button push to fail - but HFS errors could be why the boot & install failed.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
1条评论:
So i should check the battery first.
It seems that because of my laptops age the service guys will take the easy road of "logic board failure", any other advice i should follow?
If nothing happens and i get the answer i am referring to, i think about baking my logicboard.
Anyone with the same issues tried it and succeeded?
完成的
添加一条评论
添加你的答案
George 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 81
