Replaced PSU, beeping once, no video
So I previously posted about my iMac not booting up, thanks to some help I replaced the power supply and I have power and 3 LEDs. But now I'm trying to turn the thing on and get the fan noise and all that but the screen stays black and it continues to beep once every 4 seconds or so. I read that it's possibly a RAM issue, any suggestions or recommendations?
Thanks!
2条评论
The 4th LED indicates that the LCD panel is connected and communicating. The Mac "should" boot with it disconnected but just for the sake of trying maybe disconnect/reconnect the LCD panel and attempt to power on again? The single beep is also a RAM error, you might try isolating the RAM by installing one DIMM at a time and trying to boot.
由 LikeARabbit 完成的
Well I'm guessing its the monitor if the last LED isn't on. I think I reconnected everything properly though..when I unplug the LCD temp thing the fan kicks on a lot faster, it might not be anything but I feel like something simple is wrong and idk what it is. Also don't know what a DIMM is. It boots up fine just no 4th LED and no display and it beeps once every few seconds..
由 Joshua 完成的
