跳转到主内容
A water-resistant fitness tracking wristband by Fitbit, released May 2013.
20 个问题 查看全部
fitbit flex factory restore
I want to restore my flex back to factory setting how do i do it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
16个答案
最有帮助的答案
I managed to reset the device. Refer to the image below when reading the instructions:
Instructions to reset:
While connecting +5V to the middle pin and 0V (GND) to the right pin, apply +5V momentarily to the left pin.
When I did this, the FitBit reset and was able to communicate via Bluetooth again.
这个答案有帮助吗?
得分 14
12条评论:
Hi Chris,
Have you able to recharge the fitbit w/o the charger (using only the USB wires?)
I've lost my charger and still waiting for one to be shipped. I was wonder if i can recharge it until the charger will come.
完成的
Yes, just connect +5V to middle and ground 0V to the right pin (pin orientation as per my previous comment.)
The light(s) on the fit bit should start glowing. More lights will glow as the charge level increases.
完成的
What do you mean by 5+ and OV?
完成的
he means zero volts as in gound/ usually black wire, anyays Chris, i hve lost my oem charger for my flexbit and now it will not connect to my new phone, note 3, i have tried to reset it as per your instructions, what i have done is connect the red 5 volt wire to middle pin, then i connect black 0 volt ground to the right pin. I see the lights turn on likes it charging. So this is where I do not know what to do, I tried connecting a 5 volt red wire to the left pin while still connecting to the middle pin.
But it did not work, then I tried to move the red 5 volt from the middle to the left, while 0 volt wire is on right, and again nothing.
Can you tell me if there is anything that happens when you reset it, like different lights or any sign that it worked
完成的
Thank your comment. Charging is possible.
完成的
显示更多的7条评论
添加一条评论
此回答最初是针对另一个问题
OMG! I can't believe that worked!!! It took me a sec to figure out how to get it to reset using your instructions. Basically you just create a short across those two pegs for a couple seconds. Thank you so much!!!! Now my Fitbit finally synced!!!
这个答案有帮助吗?
得分 2
2条评论:
I had the exact same experience!! SO happy it's syncing now!! Thank you!!!
完成的
what did you use to restart it?
完成的
添加一条评论
此回答最初是针对另一个问题
I found a fitbit flex. I don't have a charger or the slightest idea on how to use it when I get the charger. Help?
这个答案有帮助吗?
得分 2
3条评论:
They fall of easily. Maybe you could try to return it if the place you found it has a lost and found? Someone is missing a device they paid > $100 for.
完成的
@justgenevieve
What if this person already searched for the original owner(s)?
Maybe the fit bit was found with no one in sight (ie at night, sidewalk outside, large multi business office building after hours, in a park, on the train). Don't assume things. There are so many reasons why this person may have kept it.
完成的
@Essentials Relax, it's just a friendly suggestion. I think you're reading way too much into @justgenevive's comment.
完成的
添加一条评论
此回答最初是针对另一个问题
What are these wires plugged into - powered by? A electrical device?
这个答案有帮助吗?
得分 1
3条评论:
bump, I have the same question. What tool is necessary to achieve the exact voltage?
完成的
Find a friend that has some basic knowledge of direct current (DC) electronics and get them to help out. Recommended if you are reading this.
The easiest way to get access to 5V is to get an old USB cable and charger, then cut off the end to expose the internal wires. They usually have a Red wire = positive +5V, and a Black wire = ground 0V (GND). Then follow previous instructions. Just make sure you don't connect the red to the black as you will short-circuit the wires and possibly damage the USB charger or your fitbit.
Hope this helps.
完成的
Thank you very much, that was incredibly informative, and not the least bit condescending considering how basic my question was. You have been very helpful, thanks again.
完成的
添加一条评论
此回答最初是针对另一个问题
I would suggest buying an official charger. Not only does it have a reset button, it will also work better.
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
I wish I understood what any of the above means, but I don't. I have an unofficial charger, so my Fitbit Flex will charge...but there's no reset button. Is there something I can press/do to reset it (in very simple terms)?
这个答案有帮助吗?
得分 0
2条评论:
All the thing on the official charger does is connect power to the third pin. I'm pretty sure it's supposed to be data...so here's what you do. Get a USB wall charger (do NOT plug it into your computer). The next part I'll describe looking down into your charger with the holding frame on the bottom, so pay careful attention to right and left. Do this part before plugging it in. Looking into the charger, connect the middle pin to the right pin with something metal (aluminum foil is perfect). Make sure it's not touching the left pin. Plug the fitbit charger in, then put in the fitbit. Take it out again within five seconds; if all goes well, lights should have started flashing on it. Unplug it, take the metal bit out again, and it should work normally.
完成的
This did nothing for me. :(
完成的
添加一条评论
此回答最初是针对另一个问题
I had to send back the fitbit I had because it was faulty, and now have a new one. However, it seems that I can't get the old information off the computer to set up my new one. Does that make sense?
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
If you find a fitbit return it to the company and they will find the correct owner unless you feel good about keeping a item that someone is looking for, don't be a thief do the right thing and return it.........................
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
I was recently given a fit bit flex that was found. Is there any way I can use it? Do I need a genuine charger to reset it?
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
I found a pink clip-on fitbit on top of my car and other then looking in the paper to see if it was lost I don't know what to do with it. If it is not claimed , is it useable?
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
My Fitbit doesn't seem to be charging
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
I found a fitbit flex,, I called fitbit, they will send you a prepaid box to get it to them..
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
I found a flex and emailed Fitbit. They told me they have no way of finding its original owner!
这个答案有帮助吗?
得分 0
2条评论:
Me too. They've got a register of owners, but will only reunite lost units with owners in the US and Canada. Useless if you're in the UK.
完成的
Me too ... So now what?? Should I buy a charger and reset it???
完成的
添加一条评论
此回答最初是针对另一个问题
Omg this trick works like a charm, charging works too.
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
I also found a Fitbit. The new one that just came out from what I'm reading the original charger has a reset button on it? Is that true???
这个答案有帮助吗?
得分 0
添加一条评论
此回答最初是针对另一个问题
Thank you so much. It worked in the first try
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 3,651
