跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2376 个问题 查看全部
Power off Phone with out lock button
I need to power off my phone to fix an update problem, and my lock button doesn't work. It is currently stuck in the activation screen. I need my phone as soon as possible and i can't use it because its stuck at the activation screen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Only option that I personally know of is to remove the back plate and remove battery connection. Then reconnect and turn on by plugging into a wall socket.
If the phone is on you can use assistive touch in settings.
Hope this helps,
Josh
这个答案有帮助吗?
得分 0
添加一条评论
http://www.youtube.com/watch?feature=pla...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 127
