Replacement Power Supply Options
So I am pretty sure the iMac im working on has a faulty power supply. The original 240W power supply shows a trickle charge (1 led) when installed, and when you try to power on the computer LED's 2 and 3 flash quickly (less than 1 second) then all 3 go out. I purchased a replacement PS 614-0432 which has all the same connectors, but is rated at 250W. After installing it I believe the replacement is defective anyhow (2nd hand part) as I don't even see a trickle charge LED.
After doing some looking I see it's next to impossible to find an original 240W power supply (614-0405). I see lots of people recommend the 661-4478 power supply which is also rated at 250W. I was wondering if anyone has replaced the original power supply with a newer higher wattage PS without any issues, I'd really like this to work on the second shot. Any insight anyone would have would be great! Thanks!
1条评论
Did you ever find the solution? as I have the exact same issue
由 Grif 完成的
