跳转到主内容
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
175 个问题 查看全部
Screen is not displayed, only sunlight I can see
Hi, I have an ipod nano, over a period of two months the backlight of the screen no longer wanted to see, and desepues of that time period from one day to another screen and did not look back light, if I put it to sunlight if it looks and I can navigate the ipod, perhaps moisture problem be? that's why you do not see? as I can repair? thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Do you run with the iPod, work out while wearing it, or live in an extremely humid climate? The reason that you can only see the screen in sunlight is because the backlight is out, which is a light located behind the screen that lights it up. I have had many iPod nanos have this problem, and they are all liquid damage to the backlight circuitry on the logic board. The problem is, if you sweat on the iPod or move from a cool, dry indoor environment, into a hot humid one quickly, moisture will get inside. You can try disassembling the iPod and taking out the logic board, then cleaning it with isopropyl and a small brush(gently). This may remove then corrosion off the board ad save the iPod, but remember to be very carful, since the components are very delicate and can easily be broken.
Hope this Helps
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
webmaster 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 213
