跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
How to replace the rear case?
I have an iPod Touch 4th gen, and I'm looking forward to replace the rear case, I found it on eBay but there's no guide. Is it replaceable ? I assume that it have some sort of housing inside the metal case, it is glued down? it is possible to reuse the old parts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
New case should come with internal plastic frames. Remove everything from the old device and install it into new one. You may also need new adhesives, including the copper tape.
It is highly likely to damage the button control cable and the battery, so my advice is to simply cut them, get new cables installed into the new case, install the logic board with touch panel cable connected, then solder the new cable. Finally install and solder the battery. It is the correct assembly procedure in the factory and actually a lot easier.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Victor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 136
