跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
My phone won't start..getting error 21 when restoring
Hello,
Since yesterday i can no longer start my phone unless i connect it to the cable , and it enters in restore mode automaticly.
I tried to restore it , but keep getting error 21 when doing so.
Can you help me with a solution that does not involve me taking the device to a service?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
is this a jailbroken phone? you sometimes get this error from apple not recognising your firmware. You'll need to either use iReb/tinyumbrella etc to reboot.
完成的
It is a neverlock version .
Also since yesterday the back of the phone get's very hot.I am huessing it's the battery.
I will try what you said and get back ...
完成的
添加一条评论
1个答案
已选择的解决方案
try this from techarena
Error 21 Unknown
Mac, Go to ~ / Library / iTunes /. In the Finder, you can choose Go> Go to Folder. Type or paste the path name above and click OK. - Delete all files in the iPhone Software Updates and Device Support. - Try to restore the iPhone again.
On Windows, these files are located in a hidden folder. To view these files in Windows Explorer, you must select Tools> Folder Options, click View, then select "Show hidden files and folders.
In Windows Vista, follow the instructions below: - Go to Start> Computer> Local Disk and type the following path: C: / users / [yourusername] / AppData / Roaming / Apple Computer / iTunes / - Delete all files in the iPhone Software Updates folder and Device Support. - Try to restore the iPhone again.
In Windows XP, follow the instructions below: - Choose Start> Run, then type C: / documents and settings / [yourusername] / Application Data / Apple Computer / iTunes / - Delete all files in the iPhone Software Updates and in Device Support.
If, despite these recommendations, you still have this error, make sure you have the latest version of iTunes.
Try using a USB hub.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Haiduc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 3,244
