impossible to get connection with Ethernet network
How to set the hardware factory settings router Linksys model VTR54GL v 1 . 1
Here's the Linksys support page for your unit WRT54GL Wireless-G Router It has all you should need to answer your questions.
这个答案有帮助吗?
You must connect to the router via Ethernet cable for setup/upgrade. If you pooched the upgrade buy a new router... software fixes/hacks are not really our thing here.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
Try by resetting your router and re-configure it again. Please note that your all saved setting shall gone once you have done hard reset so i would suggest if your using ADSL then get your PPPoE account setting from your ISP first and then do this.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 221
