跳转到主内容
MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
3787 个问题 查看全部
Cleaning stained plastics and refinishing
I did a logic board and screen swap yesterday as the case was damaged and heavily stained.
I decided to go all mad professor and us the damaged case to test some cleaning products/techniques and used a pot of oven cleaner that we had lying around. This is basically a very fine grit paste used for cleaning metals etc which worked fine and didnt leave any real heavy abrasion marks. What it did do is obviously remove a fine layer which gives the plastic a nice shine.
Im wondering if anyone knows of a way/product/silver bullet that can restore the shine back to the plastic as this could give an old, tired case a new lease of life and make the Macbooks I'm refurbing look that little bit better presentation wise.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Cleaning off the yellowing will be tough. You might think about going a different direction here, a few folks have used Rit Dye to color the Polycarbonate covers. Here's a vid on dying a yoyo YouTube: How to dye Polycarbonate Plastic. Here's a view of someones efforts with a MacBook MacBook dye job. After you do the dye I would recommend covering it with a clear urethane spray sealer.
If you have some skills you can use the masking tape to mask different areas off. A friend of mine did a black dye job across the cover with the area around the Apple logo a colorful beach ball.
这个答案有帮助吗?
得分 0
1条评论:
ooooh, never thought of that. Ive got plenty of old bits that can be experimented on so might give it a go. Not sure if we can get rit dye in the UK. I see some googling in my future.
完成的
添加一条评论
最有帮助的答案
Something like THIS PRODUCT may be useful.
这个答案有帮助吗?
得分 1
添加一条评论
Magic Eraser sponge works well on some really tough stains. Be sure to test a discrete area first.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kelvin stephenson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 14
总计 1,706
