跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Display won't turn on after trackpad repairs
Initially the trackpad on this mac wouldn't pop up after being clicked. I used the repair guide for the replacing the trackpad and was able to easily repair it.
After putting everything back in place, I started up the machine. It sounded like everything powered ok, but the display remained dark. When I plug the computer into an external display everything seems to be fine (including the trackpad) but the internal display stays dark.
I have already tried a few things that others have used to fix similar problems including resetting the NRAM and the SMC. I have also taken the mac apart and put it back together again just to make sure I didn't forget to plug in a cable. No dice.
The mac doesn't have a warranty, so my question is, is there anything I can do to A: fix it without buying any parts, or B: fix it by buying an inexpensive part?
Thank you for your help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Only you know if you damaged a connector on the logic board... if you did there's little "inexpensive" that can be done.
You could replace the display data cable - that is inexpensive (however that is avery advanced DIY repair). Next comes LED controller, then the screen itself.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
feanor93 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 291
