跳转到主内容
Toshiba’s Equium A210 laptop is a business-oriented version of the Satellite Pro A210 and Satellite A210 laptops.
3 个问题 查看全部
问题已关闭
Why does my laptop freeze?
Why does my laptop freeze, then blankout the screen.No response from anything.Press & hold the power button to reset, then reboot.2 or 3 times a day.
Bobby
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
最有帮助的答案
The #1 reason for "freezing" is CPU lockup, usually from heat. Dust can collect around the heatsinks and fan, limiting heat dissipation.
这个答案有帮助吗?
得分 3
添加一条评论
Have a hardware repair service replace NEC / TOKIN 0E128 OE128 capacitors as stated in:
http://www.docstoc.com/docs/79472760/NEC...
This has solved the problem with already two Toshiba laptops.
这个答案有帮助吗?
得分 3
添加一条评论
Check your power settings - Some computers do not like to be put on stand-bye. Does it happen while you are working? What are the specs of your system?
这个答案有帮助吗?
得分 1
添加一条评论
well sometimes u can try getting your penis and sticking it up your dads *@!, it sometimes works
这个答案有帮助吗?
得分 0
添加一条评论
scroo you
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 2,971
