Cannot install Tiger 10.4 software.
I have install disks for my iBook G4 however when I attempt to load disk 1, I get a Panic CPU 0. Cannot find driver for Powerbook 6.5 platform. Also says that debugging is not configured and debugging info is being discarded, then hangs. Will not boot in safe mode.
5条评论
Are you certain you're using the proper OEM grey disks?
由 originalmachead 完成的
It is the retail version of Tiger 10.4. Was told it should work on my iBook G4, 1.33 Model A1054. Yes, they are the grey disks.
由 Dan Kern 完成的
Can you give us the last three digits of your S/N.
由 Dan 完成的
ROQ are the last 3 digits of the iBook G4 serial number.
由 Dan Kern 完成的
Do you want to double check your numbers. I can't seem to find your system in the database. Here's the tool I use to verify what your system is see if you can get it to find your system EveryMac.
由 Dan 完成的
