跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
Upgrading the "Fusion" in my Fusion drive
I have a newly purchased Mac Mini with the Fusion Drive and am wondering if I can upgrade the the 128 ssd portion of the drive to a 250 or better? I have read that the ssd portion of the Apple Fusion drive is a Samsung 830. I have a new 840 pro 250 and was wondering if there may be an oportunity to clone the current ssd to the larger 840 and reinstall?
I originally bought the 840 to install with the fusion and found out it was 2 physical drives after the fact and now I have the 840 pro as a paperweight unless I choose another option.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
That's a great link and it solved a multitude of questions for me. For the most part it does not look like the benefit would be worth cracking my new mini open and go through all the work just to gain 120 extra gigs on the ssd side. In the future I may opt to go big on the ssd when pricing settles down some more but what's inside the mini right now more than meets my needs.
这个答案有帮助吗?
得分 1
2条评论:
Gee, you could have accepted it as the answer if it was the answer.
完成的
'I agree - or - my answer to put the drive in an external case. The only way these "Questions" cleared is if you the OP accept and answer OR if we the moderators vote an answer as acceptable.
完成的
添加一条评论
最有帮助的答案
Not so fast here...
You'll need to break the fusion drive back to discreet drives first before you can remove the SSD. If you don't you'll have a mess. Here's the best way to do it Breaking up a fusion drive.
这个答案有帮助吗?
得分 3
添加一条评论
In theory, just about any hard drive or SSD that meets the minimum requirements should work in the Mac mini. However changing the internal HD is''' an advanced DIY project. Take care to have the right tools, be familiar with the steps and connectors involved.
' Were I you I would put the Samsung in and external case,'' clone to it and run it that way.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 4,924
