跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
i7 and C2D logic boards interchangeable?
Hello
I have got a MacBook Pro 17" unibody from early 2009, equipped with a 2.66 C2D CPU.
Mag Safe adapter has 85 watts.
I like to know if I can exchange the C2D logic board with a later built i7 logic board (of the A1297 17" unibodies) by simply swap out my C2D board and swap in a i7, let 's say 2.2 GHz CPU, board, made during 2011?
I think it will be a performance increase because of CPU type and RAM speed.
Any suggestions are welcome.
Thanks, Stone
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Additional question: is it possible to have an A1286 board in an A1297 MacBook without major changes?
完成的
添加一条评论
1个答案
已选择的解决方案
You can not change model years... but you can upgrade to a faster logic board.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
3条评论:
Hello MacHead3
Thanks again for your answer.
If I get you right, I must use a logic board out of the same production year / series in order to upgrade - I cannot change from a 2009 C2D board to a 2011 i7 board?
Right?
Thanks, Stone
完成的
Correct. use the link
完成的
Ah, sorry - did not recognize the link. Thanks :-)
完成的
添加一条评论
添加你的答案
Stone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 673
