跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone 4s will not power on...
OK, so its been a while since i used my iphone 4s. its been in parts for about a year and I just recently bought all new hardware for it. The hardware I replaced goes as follows:
Proximity sensor
Home Button cable
Charger port
Battery
LCD Screen
I pretty much replaced everything in relation to power. I kept it on the charger for about atleast an hour. At most, the IC's under the camera warms up, but no other responses. The computer doesn't even read it, which is how i know it has not powered on. There was no water damage because i strictly took it apart to replace the exterior, but just got lazy. I also tried researching the schematics, perhaps I can try to find out where the flow of electricity stops, but its really hard to find. Looking for suggestions...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Right now i have no clue what to do...
完成的
after researching, i think my battery connector might be faulty... i will check and continue to update...
完成的
添加一条评论
1个答案
最有帮助的答案
I truly think that your problem is the same as mine! In my opinion it's either the mother board that has a short circuit OR the grounding thingies that are supposed to be mounted a certain way and we're missing it...
这个答案有帮助吗?
得分 1
1条评论:
in desparation im gonna try placing the grounding cables and pray... i miss my iphone :(
完成的
添加一条评论
添加你的答案
gtcoodyscoops 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 981
