跳转到主内容
Apple Time Capsule A1302型修理和拆卸指南。 大多数信息也适用于A1254型。
19 个问题 查看全部
Request if a breakdown manual available
Hi Guys,
I have an Apple 2TB time machine in which the reset button on the back in damaged and I am unable to reset it so that it can rejoin my home network. I want to remove the HDD and install it another enclosure and use as a backup external HDD. Apple do not repair these, as you probably know.
If there is no breakdown manual and/or video can you suggest the safest way to break open the TM and retrieve the HDD from it?
Also, can you suggest a suitable enclosure that I could use to house the guts of the TM?
Many thanks for your help.
Cheers
Roger
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I'm assuming your 2TB Time Capsule is the shorter, older, model.
This iFixit guide should walk you through removing the hard drive. The gist of the repair is you will remove the rubber bottom using a heatgun or hairdryer along with a paint scraper to work through the adhesive. Once the rubber bottom is removed you can unscrew the metal bottom cover and access the hard drive. Honestly, the rubber bottom is the biggest hurdle in this repair, once it's removed the hard drive is then very easy to remove as well.
This video shows the process as well.
Once the hard drive is removed you can install it into just about any 3.5" SATA hard drive enclosure. The guts of the Time Capsule would be a bit harder to source an enclosure for. If it were me I would try to remove just enough to perform the reset, then reinstall everything into the original enclosure. The rubber bottom could be placed back on without the adhesive which would make future repair much quicker if necessary. If the reset button is hard to reach then you may be able to widen it's access hole once the Time Capsule is all apart.
Hopefully that helps!
这个答案有帮助吗?
得分 1
1条评论:
Many thanks for your help. The video was very helpful.
完成的
添加一条评论
添加你的答案
rogera 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,469
