跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
New battery won't boot
Installed a new battery 616-0435 it booted up fine til the lock screen the battery died so I put it on charge and is showing the charging symbol but has been like this an hour and won't turn on.. Any ideas
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
sometimes it's just a battery that has sat on the shelf for a long time (these phones are years old, so the battery probably is old stock) get out your multimeter and measure the voltage coming from pins 1&4 (I think from memory) if it is less than 2.2 then you can't get it to charge. I use a 9v rectangular battery and connect 2 wires up to the battery and then the pins to give it a "boost" for about 30secs then it should charge.
这个答案有帮助吗?
得分 2
1条评论:
failing that I'd send it back..
完成的
添加一条评论
添加你的答案
con 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 159
