跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Back camera not working anymore
Hi, I had to replace the power and sensor cable. By doing that I killed the display cable so I had to replace it as well.
After replacing the two things I realized that the rear camera is not working anymore.
If checked the contacts and the gold bracket, but all seems to be in well condition. I also couldn't find a broken camera cable.
Tried hard-reset. All other hardware operations are working except rear camera and led light.
Also tried to restore the whole device.
Any suggestions?
PS: The gold bracket is between case and logicboard? And not above logicboard?
Update
Today I got the new camera and replaced it.
But it doesn't work.
Any other suggestions to do or to check?
// Front camera is working when I'm using facetime.
Update
The U10 component (http://www.moulnisky.com/downloads/Apple...) seems to be a little bit damaged. Do you think that could be the reason?
How to remove the U10 component from the logic board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Hello,
The gold bracket should look like this when it is installed correctly.
This might effect the cameras operation so ensure this is correct before we go on to anything else.
If you have confirmed this bracket is correct and the camera still will not function then i suggest replacing the camera, seems like you haven't had much luck on this one. This guide will help you through the replacement (not like i think you need it).
Please let me know how you get on and as always if you ever need any help just ask.
Cheers
Brendan Mills
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 0
2条评论:
Hi I rechecked the gold bracket and it's installed correctly. I just ordered a new rear camera. I'll keep informing you if it helped changing the camera.
完成的
Same issue. Bracket was in place correctly.
I tried replacing the camera, still no go. Anybody find a solution?
完成的
添加一条评论
Hi , I seem to have the same problem and did everything possible. I even replaced the camera too. So with all that said hopefully my fix will be your fix. I called Samsung direct and they told me to send it to them. Not being in warranty the cost was $70.00. I will let you no if that works when I get it back in 7-9 days :(
这个答案有帮助吗?
得分 0
1条评论:
This post is about an iPhone problem. If your phone is a Samsung, it would be better to delete your answer as it is misleading to people looking for an iPhone answer
完成的
添加一条评论
After replacing my power cable my rear facing camera & LED stopped working as well. I took a Q-tip dipped in rubbing alcohol and wiped down the gold contact and metal camera surface. My camera and LED started working after that.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matthias 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 16
过去 30 天: 31
总计 4,047
