跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Cant power on with a non-original screen replacement!
Hi everyone!
I cant think of any other place to ask this, and if anyone has ever had this issue before please help.
So here it is. My client broke the screen of his 4s. I bought a non original screen replacement from ebay. When I installed it the device didnt want to boot up, i pluged it into the wall charger, my PC, no result - like its dead... So i decided to give it a try with some of my other screens, original (cracked but functional) and nonoriginal, not surprisingly it powered on... My guess was that the replacement was damaged, so i went to a local(!) store and bought a new screen, the guy at the shop showed me that it worked by connecting it to a 4s motherboard. When i came back and installed it, i was astonished by the fact that the new scree had exactly the same problem! Well alright..., its just a coincidence..., so i went back and explained the situation, barely convincing the guy at the store that it wasn't my fault. Finally, when i got the screen, i immediately installed it and what do think happened? Same story! Cant power on, no signs of live, nothing, just the processor heating...
Is the third screen! It cant be a coincidence! It just drives me insane! Idk what to do! I cant be that dumb to ruin 3 screens while successfully testing it with 4 other screens!
Please help me! It just doesnt make any sense...:((
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
funny im having this same problem... the logic board heats up so current is running through, however, not being picked up by the computer nor charging... the dock connector is brand new, as is all the parts... so idk...
完成的
添加一条评论
2个答案
已选择的解决方案
There are some iphone 4s screens that require an IC chip on the LCD cable in order to work, these are very rare to find but exist, my guess is you are 1 of the lucky few with that model
这个答案有帮助吗?
得分 1
添加一条评论
I read in another post that IOS5 may not work with some of the newer replacement screens.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sith 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 226
