跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
Partial Digitizer Functionality (new screen same issue)?
Recently got an iPod Touch 4 in for repair, customer asked we diagnose his device.
The device was fully functional, except the digitizer would only work on the very left and very right edges, occasionally at the bottom. Assuming a bad digitizer, we replaced it.... only to find the exact same functionality as before!
We have tried other screens as well, but we are concerned about wearing down the connections. Has anyone else had this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Hello!
I myself have never encountered this before but I would start by cleaning up the connections using isopropyll alcohol. If this does not resolve the issue then check the connections and check no pins are bent within the socket. I have experienced bent pins in the digitizer connection before but this caused a none-responsive touch screen rather than partially responsive but I'd still check it out, if they're bent then do your best to straighten them. I used a tiny sewing needle to achieve this but I'm sure there is a much better suited tool for the job.
Before claiming the pins to be straight compare them to ensure they are actually bent, I suggest using a magnifying glass to have a closer look.
Get back to me with the results :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
linda70 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 242
