跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Earpiece speaker replacement problem
I recently replaced the earpiece speaker in my iPhone 4S and everything went well but now the mic doesn't work when I talk on speakerphone only. I am guessing I will need to replace either the power and sensor flex cable or the headphone jack cable, but I don't know which one contains the external mic?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Anyone have any information on this subject?
完成的
添加一条评论
1个答案
已选择的解决方案
You need to replace headphone jack cable in this case.
You can confirm that microphone used for talk on loudspeaker is broken by recording a video. See if it records any sounds. If nothing happens or it makes noise - replace headphone jack cable
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mcw4au 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 175
