跳转到主内容
加入维修社区 - 创建账户
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
no display or backlight
Ipad 2 back-light or LCD not working. unit was not dropped. I have sound because it lets me know i have email. digitizer works, i will swipe my finger where you unlock and it makes the unlock sound. I attached to my tv via hdmi accessories cable and ipad displays on tv. not sure if it is logic board issue or needing new LCD. Please Help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
i had a repair on iPad 2 recently, in that case it was weak connection between LCD and LCD cable, had to clean it and reconnect. It worked fine.
But there is also many other possible options can be as well:
1) bad LCD
2) water damage
3) problem with motherboard (backlight filter and some other ICs)
这个答案有帮助吗?
得分 3
1条评论:
Thanks Vlad, I will check the LCD cable to start.
完成的
添加一条评论
添加你的答案
Kevin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 19
总计 938
