跳转到主内容
Released around 2010, the Dell Inspiron 15R N5010 is a 15-inch laptop with an Intel processor and dedicated ATI Radeon graphics card.
49 个问题 查看全部
How to get WIFI and Bluetooth drivers for dell N5010?
I need the wifi and bluetooth drivers of the dells as i can't get them in any site ....plz any one can help me for finding this.....
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
1条评论
just visit dell site to download the driver visit https://goo.gl/SSBGrW
完成的
添加一条评论
3个答案
已选择的解决方案
First you have to know which wifi card is installed on your device but i link you all possible drivers.
Go to this site and click in the menu Drivers&Downloads there you can find all drivers.
http://www.dell.com/support/troubleshoot...
这个答案有帮助吗?
得分 3
添加一条评论
Apparently seems like your W-LAN card is either disabled from your network connections or may be there is some hard switch which turned off. All you need to go open network and sharing center then click view network connection to make sure that you Wireless connection is not disabled in any case it should have to be enabled.
Other way is to check on your keyboard from top F1 to F12 keys if you can see a Antenna sign on any of key then press that key by pressing Fn key together.
If the problem still persist then I would recommend you to go on your manufacturer`s website to download the latest driver and update your driver. Good Luck
这个答案有帮助吗?
得分 1
添加一条评论
Thank you very much/ my laptop is i5 Aspiron N5010-window 7 64 bets
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Raviteja Adusumalli 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 12
总计 20,589
