跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
What to do next? Battery replacement problem.
Ive stupidly tried to remove the battery connection with a flat head screw driver whilst the phone was on. I saw a small spark come from the phone, reassembled it perfectly now it wont turn on. Any idea which component i would have broken?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Why use a flathead when the screws are + shaped
完成的
添加一条评论
2个答案
已选择的解决方案
you may test your components independently. The only thing you may hope is not to have endamaged battery connector pins or the logic board. Next time, you'd rather use a plastic knife for example and an anti-static wrist strap. You may find all you need by following the links below.
Hoping to have helped you,
Give us some feedback
Vincent !
[关联产品丢失或禁用: IF145-047]
Digital Multimeter
Digital Multimeter图片
产品
Digital Multimeter
$19.99
这个答案有帮助吗?
得分 1
添加一条评论
Well by suddenly disconnecting the power, you could have done damage to the software of the iPhone. You should always turn it off to prevent damage and data loss. I would think you may have to replace the battery. Also check to see if anything looks different ie there is an area that has turned black . If thereis gently clean it using isoproyl alcohol not the kind that you have in a medicine cabinet, that has to go low a concentration. Get some with the highest concebtratiom you can get. Then clean the area where u see damage and if that does work the part may need to be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vinnie Ebbrell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 167
