跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone 5 dead LCD after rear case replacement
I replaced a customer's iPhone 5 rear case today and now the LCD appears completely dead. The mute switch makes it vibrate so I know it's on but replacing the front didn't help (or a hard reset obv).
Could I have blown a fuse or what could be the problem?
The logic board doesn't appear damaged.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Mabe could you verify that the connectors are connected well and all the pins absolutely clean. It looks like your display is just not supplied/connected. Remind that even a small peace of dust can cut the connexion...
Hoping to have helped you,
Give us some feedback !
这个答案有帮助吗?
得分 0
1条评论:
Absolutely clean and connected :-/ I'll have a partner put it under a microscope today.
完成的
添加一条评论
Hi
Happened to me the same problem, what I did was to inspect well near the connectors and set me well that a connector had broken and what I did was I made a bridge with a silver writer. and it worked but I had to connect a new screen for it to work and then place the iphone screen.
And iphone is working properly
Bad Part
http://www.flickr.com/photos/99104195@N0...
Fixed with Silver Writer
i use a Macro Lens for iphone 5
Link Silver Writer
http://www.amazon.com/CIRCUIT-WRITER-SIL...
never use it direct the writer, put some on a sheet with something that has the fine point you can do it without touching other connectors or you can make a short circuit.
这个答案有帮助吗?
得分 0
添加一条评论
Hello Anders,
How did you fix it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anders 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 8
总计 816
