跳转到主内容
Broken logic board LCD connector
Hi, I am having some major trouble. It seems as if the socket on the logic board to connect the lcd is broken. The retainer gold bracket that goes over the socket has fallen off. The plastic on the socket also seems to have broken off. Is there a fix for this without buying a new logic board please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Could you upload a pict showing the damaged connector and then we may be able to give an accurate answer.
完成的
I have the exactly the same problem as Holger.
I have a degree in electronics, so I could replace the connector on the main board, if I knew what it was called.
Anyone knows?
完成的
添加一条评论
4个答案
已选择的解决方案
Not an ideal repair but if it were mine I'd find a piece of the yellow tape Apple uses and make as good a connection as I could and tape it in place. Then I'd cross my fingers and see if it worked. Otherwise you are looking at logic board replacement. Ralph
这个答案有帮助吗?
得分 2
添加一条评论
hi, newhem, i don t know uf you can fix or not your problem chek this.
http://translate.google.es/translate?hl=...|es&u=http://www.dhgate.com/wholesale/laptop%2...
there you can buy the conector what you are looking for, then you need a hot air soldering to take out the broken conector and replace for the new one... the hot air soldering cost aproximately 60/80 Eur. regards, Luis.
这个答案有帮助吗?
得分 1
1条评论:
Nice share on the part Luis. You can put your email address in your profile not in your answers.
完成的
添加一条评论
I have nearly the same Problem. Fluid went between the connector and blow up 1-2 Pins.
The Display dosn't work. But I connect it to an extern display. It works.
I have to buy the complet display, because the display and the wire/connector is one piece.
这个答案有帮助吗?
得分 0
添加一条评论
You could find a friend who can solder for you, I am not sure how small the pins are on the newer macbook pro's as I am just now getting one and haven't torn into it but the older 15" legacy ones were decent enough to work on if you had some thin solder and a fine tip.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
newhen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 4,789
