跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Why wont the screen fit?
Hi, I tried to fix my cracked iPod touch with a screen replacement, and it was going great until the last step. I tried it out before gluing, and the screen worked great. I don't know what to try! Does anybody have tips? Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Some time you need to bent the chrome on the 4th gen to get the screen to fit as you might have bent it out of shape when the screen was smashed
这个答案有帮助吗?
得分 2
添加一条评论
Con is correct, usually the bend is where the impact was and depending on where it is located it should be fairly easy to bend back, just be careful. Also double check that your adhesive is laid flat and there is no debris such as broken glass, old adhesive or dust where the screen sits.
这个答案有帮助吗?
得分 2
1条评论:
Thanks, do you know the best way to put the screen back on?
完成的
添加一条评论
添加你的答案
mar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 115
