跳转到主内容
加入维修社区 - 创建账户
Fun to Imagine Cash Register (TRU) Product#: L6485 Released: 2007 Discontinued: 2011 Ages: 2 years + up Product Description Get imaginations busy with a classic cash register! Ring up some fun and watch it add up with colorful, numbered coins to sort and drop, buttons to press, sounds and popping, spinning, rolling action.
How do I reattach the spring inside the cashregister?
The cash drawer would not open . I took the screws out and disassembles the toy. There was a spring laying inside. I can not see where it attaches. My grandkids love this toy as much as my kids did and I hate to give up on it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I know this is old, but just in case anyone else has this problem; the eyes of the spring attach to the two small pegs behind the two large ones. Just slip the loops on the spring over the tops.
完成的
添加一条评论
2个答案
已选择的解决方案
1. On the inside of the base is a long coiled spring. First hook this back over the end of the central drawer runner. Have a ruler or similar flat item handy to release it later.
If the mechanism inside the cash register has come apart, read paragraph 2. If not, go to 3.
2. Take the body of the cash register and insert the narrow end of the brown plastic lever through the white plastic assembly, until it engages with the handle mechanism. You will then feel resistance when turning the handle. There is a flat metal strip in the middle of the assembly. On the side of the brown lever is a small projecting peg. Put this behind the metal strip. Put the thicker end of the lever through the rectangular gap in the white assembly.
3. Place the drawer into the body of the cash register so that the back of it engages with the V shaped notch on the plastic lever.
Hold the drawer and body together with one hand and carefully lower them on to the base. While there is still a small gap under the drawer, insert the ruler to release the coiled spring. This will engage with the projection under the drawer.
Push everything together and replace the screws. Job done!
这个答案有帮助吗?
得分 5
11条评论:
This helped a lot. One remark on point one. There are two pegs on the side of the base which the hooks of the spring attaches to. This creates a crossbow effect at the back of the central drawer with the spring. The spring therefore fits perpendicular to the central drawer.
完成的
Glad it was helpful. Good point about the spring. I'll add it to my answer to another similar question on the site.
完成的
So I followed your directions and for the most part I got the toy back together but the lever isn't operating properly. I have to swing it one way to open the door and then swing it back in order to shut the door and have it lock in place. Also the bell isn't ringing. Any idea what I did wrong?
完成的
Mine works exactly the same. You have to turn the lever forward to open the drawer, and I think the bit that rings the bell is missing. But the coins can still be sent into the drawer or out down the chute. Not perfect but it's a very old toy, and the children have fun with it.
完成的
Thank you!!! This toy was loved by my children and now my grandchildren love it. Someone put a Lego into the coin slot causing the drawer to not open. (No one would confess to the crime but I have my suspicions.) We removed the bottom and the spring released. Following your instructions, it's as good as new!
完成的
显示更多的6条评论
添加一条评论
Thanks so much....it works! I just ordered replacement coins on Etsy so my son doesn't have to cram random objects in there. ;)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephanie 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 163
总计 24,646
