跳转到主内容
iMac G5 Freezes After Startup Even After Hard Drive Replacement
My Imac G5 was freezing up during or after start-up. I sometimes reached the desktop and it would freeze. I got onto the internet a couple of times before it froze, as well. I also got the lines going across the screen (in random/intermitent patterns). I found a few sites that stated the problem was likely the hard drive going bad, so I replaced the hard drive and still get the same problems. I tried various scans and fixes like the ones in Disk Utility, but still the same problem with the freezing and lines across the screen. The hard drive is now a new one, so is this still a hardware issue? I even tried a fresh OS install on the old hard drive (no changes) and the buyer of the new hard drive did a clean install of Snow Leopard.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Is you new HD SATA 1 (1.5GB/s)? If not, it could still be a hard drive issue. SATA II drives can work with this machine... SATA III drives probably wont.
完成的
添加一条评论
1个答案
已选择的解决方案
Connect to an external monitior. If the lines don't go away you have a video card problem dealing with this issue is an advanced DIY project.
If the lines do go away the problem could one of a couple internal components... a cable or the LCD.
The freezing could be your CPU or RAM.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
1条评论:
Thanks, I'll try that and let you know what happens.
完成的
添加一条评论
添加你的答案
Kimberly Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 6
总计 397
