跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Where can I get a replacement wi-fi EMI shield long screw?
Hey all,
I recently brought a iPhone that was in pieces from my friend, I put it back together but I get very poor wifi signal. After looking at it I conclude that this is caused by a missing 4.8mm screw at the top of the iPhone in the EMI shield. I was wondering if anyone knew where I can buy a replacement screw, or if there is another quick fix.
Thanks in advance,
Ryan
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
You can get a whole 47 pc screw set on ebay for only 2 bucks.
The screw you are looking for will be there.
http://www.ebay.com/itm/47-Piece-Full-Sc...
8
Also make sure the silver metal spring on the wi fi antenna cover that the screw goes into is still there and didn't fall off.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan vadera 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 509
