跳转到主内容
加入维修社区 - 创建账户
Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
MacBook won't boot unless done in safe mode
When booting up, my older macBook Pro 17" will get as far as the gray Apple logo on the screen then go to a white screen and hang. I can restart in safe mode and the replacement hard drive is only a year old. My CD drive will not allow me to use a disk to re-install, it just reads it then spits it out.
Is this a logic board problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Does the grey installer CD/DVD that came with your system or logo'ed OS-X installer DVD spit out when you try booting under it (not in safe mode)?
完成的
添加一条评论
1个答案
已选择的解决方案
the problem can be the graphics driver, reinstall the OS and check.
这个答案有帮助吗?
得分 1
3条评论:
I am unsure how to re-install the OS in that my optical drive won't load a CD (10.6) by holding down the "C" key during boot up. Since my most recent OS (10.7.4) came from the APP store, not a CD, how do I re-install without a physical CD?
完成的
You should still have the installer app for Mountain Lion. You'll need to run it to install on a removable HD or flash drive a bootable OS. Once you get it on the second drive you should then be able to boot under it. If you have Snow Leopard you might find that a better OS to create a bootable CD as you can drag copy it over to the optical drive.
完成的
target your machine to your friends laptop and try to install. press t while booting the hdd should show up on your friends machine and then install (connect using firewire).
完成的
添加一条评论
添加你的答案
ksoudani 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 966
