跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Alternating screen from blank, Apple logo, very low battery charging.
Have iPhone 4 that only came on when plugged in to charger and then it only showed the Apple logo that would come on then go off then come on then go off ..... Read on the site that I should try replacing battery. Replaced battery with new one then it would alternate (when plugged into wall charger) Blank screen, Apple logo, picture of low battery (red) charging over and over. Left it plugged in cause it looked like it was charging, after 13 minutes it went completely blank and will not respond at all now
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
You need to replaced the battery its not taking a charge. You can get it hereiPhone 4s replacement battery. Replacement is straightforward. Follow the guides provided here and your phone will work.
iPhone 4S Battery图片
产品
iPhone 4S Battery
$16.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
stalmage62 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,610
