跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
iPhone 3GS won't boot at all
My iPhone 3GS won't boot at all. I bought it off of ebay, and it was listed as water damaged. Only the water indicator in the dock connector was active, but the other one at that top of the phone was not active.
I took the phone apart, soaked it in alcohol, gently cleaned it with a toothbrush, and finished it off with CRC electrical contact cleaner. I even removed the logic board shielding during this procedure.
If there's a simple cable I can replace to get it working, I'd be happy to do so. The one cable coming out of the display that doesn't "click" in seems to be burned, or something like that. I've attached photos for reference.
I cleaned up the copper side of the cable, but the back side that appears to have a black dot - I can't clean that side. What cable is this, and is it causing my problems?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I would try a dock connector seems like the battery's flat and the docks broke
这个答案有帮助吗?
得分 1
2条评论:
Is there any way to repair the dock connector, rather than getting a new one? I already cleaned a good bit of gunk out of it, and it looks really clean at this point.
完成的
If the parts not going buy a replacement part it's so cheap
完成的
添加一条评论
添加你的答案
Casey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 344
