跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
Clean dust shadows from LCD
There's any guide introducing to clean LCD and rear panel? I'm stuck on pull off the entire display.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
If you remove the glass panel with a suction cup, you can clean the inside and outside with an iphone or ipod microfiber cleaning cloth (thats what i use)
alternatively, you can use a dust/lint roller on the screen (apple has a kit for it, but its not cheap, or made to be bought for a once off use, here is the link)
The difficulty is making sure you dont leave finger prints or smudges on the underside of the screen. also, try and find as clean an environment as you can, as dust will always seem to settle in between the layers while you work on it. A tip is to tilt the display as far forward as possible, then dust falling straight down wont land straight on the LCD panel...
It typically will take a few on and offs to get it perfect, but having natural light from a window helps show up any smudges in the process.
have fun. :-)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Marco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,053
