跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
Where is the bluetooth card?
I've read through the teardown and the repair manuals of the MacBook Unibody but nowhere can I see a reference to the bluetooth card.
The card on our late 2008 MacBook unibody (Alum) is not functioning, but to replace it, I've got to find it first!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
I found the location-- its part of the display assembly with the airport card and the isight camera. I have not however been able to locate it on the teardown. I am including the link for a display unit but if it were me and that was all that's wrong I'd get a inexpensive bluetooth dongle for a USB port. Good luck whatever you decide Ralph
http://www.ifixit.com/Mac-Parts/MacBook-...
http://www.walmart.com/ip/IoGear-Bluetoo...
这个答案有帮助吗?
得分 1
添加一条评论
Out of curiosity, is the isight working OK? Both the bluetooth and the isight share the same cable from the logic board to the top edge of the display assembly under the glass.
If the isight is also not working then it is more likely to be a problem with the cable.
In the best of all worlds the cable can sometimes come unseated in the logic board and can simply be reseated.
这个答案有帮助吗?
得分 1
1条评论:
that was sure easier than diving into the display assembly!
完成的
添加一条评论
Yes reseat the cable...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
robert Seith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,824
