跳转到主内容
1.83 GHz Core Duo 处理器 或 1.83, 2, 或 2.16 GHz Core 2 Duo处理器 A1208 (EMC 2104/2110/2114/2124)
Reassembly problem
I have a 17" late 2006 2.0 GHz intel core duo EMC No.: 2114 iMac lol. The optical drive said November 2006 if that makes any difference. I took apart the RAM err bay thingy (sorry) and lost the metal springs. They look like a paper clip. I didn't see a guide with pictures for how to do that. I tried myself and gave up after a while lol. I also have a few screws missing (who doesn't? lol) I might need to replace I guess. I replaced the RVRAM battery, tried the "control+option+p+r" reset but no luck. I went ahead and put the RAM cards back in with the cover holding the cards in hoping it would still work lol :P. I've never had anything done to the computer since I bought it that was good, bad or otherwise till now. I'm also brand spankin' new to this stuff. I haven't checked any of the diodes you menctioned earlier so that may be my next step? Could it be a power supply issue? I want to replace my optical drive, replace my old HHD with either a SSD or a new higher storage HHD, put in 3 GB of RAM and Lord help me I guess replace whatever else. It's been both frustrating and interesting. If nothing else I'm learning something new and becoming a more informed consumer, so I think I'll go ahead and see this through. I also have some original music I'd like to recover from the original hard drive. Maybe i can bring it to my church and record our band there as well! Great site, thanks again.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
If the RAM is not locked back in (pressed completely down to where it "snaps") your machine should not start... but It should also give you a "no RAM" error code either throbbing light or beeps.
You can't just stick a new SSD or HD in that old machine.. It uses a (1.5 Gb/s )Serial ATA drive most new drives are too fast for (3 to 6GB/s) it and so you'll have hanging/freezing problems.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Johnny Deester 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 126
