跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Booting loop after replacing power and sensor cable
I just replaced the power and sensor cable of my iPhone. Unfortunately it won't power on any more after the replacement. I can't turn it on via power button but if i connect it to my Ma, i will go on and display the apple logo on the screen. After a few seconds the logo disappears and it powers off. Then it starts right at the beginning (Power on, Apple logo, power off, ...). I'm suspecting a booting loop, but I have no idea how to fix it. Is there a possibility that the replacement power and sensor cable I bought doesn't work correctly? That would explain the not working power button. Any help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The first thing I would check is the Battery and Battery connector. Make sure the battery connector is undamaged and make sure the screw under the battery connector is tight and in all the way so the battery connector can fit down all the way and snug.
Also, check the button itself and make sure it clicks normally and isn't screwed in too tight. A lot of the time the aftermarket button will need "tuned" a little bit to make sure it clicks properly and isn't just pressed all the time because of the tension put on it by the screws.
Hope this helps!
这个答案有帮助吗?
得分 0
2条评论:
Thank you for the quick response!
Just tried reconnecting the battery connection - seems fine to me. But the phone is still not responding to my commands.
Maybe I should also mention that itunes doesn't recognize my phone when I connect it to my Mac.
The button clicks perfectly. Nevertheless I will try to loosen the two screws a little bit. I will let you know if that worked for me.
完成的
Thank you so much, my phone is working again! It was the battery connector.
完成的
添加一条评论
添加你的答案
martinhumnig 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 818
