跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
My iPod touch is disabled and my home button is broke?
So last night when I was watching the game and my sister saw my code and i changed it. I forgot the pass and it got disabled, but i saw a DIY to fix it but also my home button is broken so i dont know what to do i wanna cry cause all my 4,000 photos are on there and i dont think i saved it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
添加一条评论
6个答案
最有帮助的答案
well actually you can try to use a application called reiboot which can put your iphone into recovery mode without home button and then you could go on itunes and wipe :/ sorry m8 only thing i could say
这个答案有帮助吗?
得分 2
添加一条评论
Unfortunately it sounds like you may be in a bit of hot water. The only proper way around a disabled iPod is to restore it. This will wipe all data. Its always important to have a regular backup. And if its really important, a backup of your backup of that backup stored off site.
Im not positive that iTunes will let you restore it unless you put it in recovery mode or DFU mode. Both of these would require the home button working. The home button itself is very inexpensive and not too difficult to replace. See the guides here
iPod Touch 4th Generation Home Button Replacement
Hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
and this is why i dont f*ck with Apple. i had to buy a whole new device because i called apple and they said i had to pay 15 bucks to know how to fix my ipod. so ridiculous. switched to Galaxy and has had absolutely NO issues. forget apple :)
这个答案有帮助吗?
得分 1
添加一条评论
there aint NOTHING that can be done .
这个答案有帮助吗?
得分 0
添加一条评论
do you download reboot on your computer?
这个答案有帮助吗?
得分 0
1条评论:
Yes. I had done the oh so inconvenient google search for you and it's a 6MB download.
完成的
添加一条评论
Don't worry, first ask your sister what is the pass code, then go on settings and set a on screen home button.
fixed :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Isabelle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 15,457
