跳转到主内容
This Power Mac G4 has Mirrored Drive Doors.
80 个问题 查看全部
问题已关闭
Video card upgrades available?
I am upgrading my G4 Power Mac MDD dual 1.42 MHz PowerPC (FW 800) that was the first model to have the 800 Fire Wire installed. Apparently, this model is a bit picky about some of the components compatibility. If things aren't just right the computer won't work.
This came with an ATI Radeon 9000 Pro with 64MB of DDR SDRAM video card which has gone belly-up. I not only have to replace it, but I want to upgrade to a faster, better performance card. I have sought the advice of several sources, but most people I have talked to are unfamiliar with this model and their suggestions have all been wrong.
I now have several video cards which I can't use sitting around taking up space. All of them reportedly work on the QuickSilver models, but not on the (FW 800) Model. CAN anyone help me, please???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sorry to say your in for a bit of work here.
Most of the GPU vendors have moved on with PCIe boards and your system has the old original PCI interface. So your only option here is to look at the used market for a workable board.
I would recommend replacing with the exact same ATI Radeon 9000 Pro you currently have looking on eBay, that would be the easiest. As you are still running an older OS-9 or early OS-X using Rosetta services your upgrade options are very limited here between the drivers and any tech support.
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 226
