跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Why won't my 4s turn off?
Step one in replacing my iphone 4s's battery is to turn the phone off. It repeatedly reboots to "on" whether I use the on off button or the assistive device touch technique.
Other suggestions besides just letting the battery go dead?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
This is most often caused by short circuit of the charging port. Clean the charging port very well with toothbrush, Isopropyl Alcohol, lint free cloth, etc. If after thorough cleaning still reboots with OFF, then the next step would be replacement of the charging port with the attached flex cable.
这个答案有帮助吗?
得分 2
添加一条评论
You could let the battery drain or just removed it with a anti static screw driver and spudger
这个答案有帮助吗?
得分 1
添加一条评论
No problem it's now solved I tried it with my oralB toothbrush and as cleaner I used denim shaving cream it's now switched off. Real experience just now. Thank you much Mr OralB n denim with whole team. Zahid
这个答案有帮助吗?
得分 0
添加一条评论
Wow! After calling Rogers and Apple several times today, I saw the suggestion here about cleaning the charging connection with a toothbrush! I felt like an idiot doing it, but darned if my phone finally turned off after a good brushing!
I have been trying for 24 hrs with no luck to turn it off, and the toothbrush did it! Just a dry soft bristle brush!
Beats paying for a replacement phone or being without it when I send it in for repairs!
Thanks for posting everyone! Your ideas do help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mmooy1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 14,164
