跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Stripped/rounded philips screw to the power button, how to get it out?
I've burred the head of a philips screw to the power button that I'm wanting to replace, so I can't get it out. Is there any suggestions how to get it out without damaging anything else?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
they sell a good tool to fix it, it helped me out a few times
Precision Screw Extractor Set
Precision Screw Extractor Set图片
产品
$24.99
这个答案有帮助吗?
得分 1
3条评论:
how exactly does this work? I might consider buying it
完成的
the tip is made out of 4 points you can press them down into the metal screw and unscrew it :-)
完成的
How well does it grip it and how much force do I have to apply?
完成的
添加一条评论
添加你的答案
Patrick Lee 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 144
