跳转到主内容
加入维修社区 - 创建账户
Laptop doesn't recognize the new battery, and then neither the old one
I followed all the instructions to change my battery, and I did it correctly. Then I tried to switch on my computer but it didn't do anything. So I tried to replace the old one and it happened the same thing! So I tried to reset the SMC as the apple website said. When the computer started it seemed to be everything ok but then the toolbar said that there was no battery detected. The same thing happened either with the new and the old battery following the same procedure of resetting the SMC. What do I have to do to let the battery to be recognized?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Recheck all your connecions and be certain you didn't damage a connector when you disconnected it. Often problems with reassembly is that new DIYers "think" they have good connections when they are not square, snapped in or locked down.
If this answer was helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
2条评论:
Thank you! And do you know how I can check if I damaged or not a connector? Thank you again
完成的
Use a magnifying glass look for bent, torn or missing pins (sometimes the connector is ripped off the board)
完成的
添加一条评论
添加你的答案
arduins93 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 205
