跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone 5 power button and home button doesn´t work + no service
Hi, I just changed the flex for the power button in my iPhone 5 from another iphone 5, but when i changed it, It wouldn´t work. After the change, the home-button didn´t work either and it said i had "no service".
I have just spend hours trying to work this out, i have disassembly it many times and tried to find the failture, but i still do not find it!..
Please help me..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
I have same problem, any one please?
这个答案有帮助吗?
得分 0
添加一条评论
when the phone is open you can connect the two little gold springs at the bottom with a screwdriver, to make the phone think the home button is pressed. does that still work?
if so there must be something wrong with the home button flex cable.
if not, clean the contacts of the lighting connector or replace it
keep us posted
about the reception? are you sure all cables are connected? be sure the two back thin ones are seated properly, also try cleaning them
这个答案有帮助吗?
得分 0
添加一条评论
I'm going to refer you to this : Home button + Power button doens't work after display replacement?
apparently there are 3 tiny chips on the left side of the gsm card reader that create this problem if they are damaged. You'll probably need to go to a repair shop to get them replaced.
这个答案有帮助吗?
得分 0
添加一条评论
"No service" or "Searching" is what I always see after repairing a phone up to a level where the battery was disconnected.
It's something with the physical memory I guess, but anyway, you have to connect your phone to a wifi network or itunes, wait a bit for the clock to auto adjust and than switch flight mode on & wait 10s & off. Sometimes you get a popup "server identity not checked" or smth like that. Just press proceed.
This should fix the "no service" issue.
The homebutton: use a bit of sandpaper (P500) to clean the two copper tabs on the phone. Make sure they stand upwards enough to touch to two copper dots on the homebutton ribbon.
Power button: Since it's bracket has a hinge, it's very tricky to tear the ribbon cable when installing...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Torgeir vikane 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,614
