跳转到主内容
完整的拆卸和安装指南,支持大部分的 iPods, 包括 iPod original, mini,shuffle,nano,classic 和 touch。
6217 个问题 查看全部
问题已关闭
Why wont My iPod turn on?
I hold the button and it is defiant!
I got it pre-owned.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You're probabally right.
完成的
添加一条评论
2个答案
最有帮助的答案
dead battery, or maybe it is just a broken wire inside, but really what do you expect when you get it pre-owned?
这个答案有帮助吗?
得分 1
添加一条评论
If you have background apps running, it should die, so if it doesn't it will take quite a while for it to die. So you need to let it die. After you think it's dead, turn it on, and you should see the dead battery sign. so plug it into your computer and access iTunes, then just let it sit there, play around with iTunes for a bit, and it should turn on when it's charged enough to turn on. That's how I got mine to work. Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 574
