跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
问题已关闭
microphone compatibility between MBP and MBU
hi
i was wondering if the microphones for 13" MBPro and MBUnibody could be interchangeable? those for MBP are less scarce and less expensive to get hold of.
is it the same connector, perhaps same wires too?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Depending upon why/what you need the microphone for (Skype/Face time/other) a USB microphone would work. If you're doing voice communication a voice quality unit with headset/earphone also eliminates feedback.
Remember to return and mark accepted the answer that best solves your problem.
这个答案有帮助吗?
得分 1
1条评论:
normally, i wouldnt bother. elegant solution, that usb or perhaps just external mic. but...
laptop will go to my mum. shes extremelly clumsy. already have destroyed a few laptops by pulling the usb conntectors out wrong way...
so i want to make sure there is nothing possible to break off of this one...
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 85
