跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
How to correctly solder power volume flex cable?
I have an ipod touch 4th generation and I recently tried to solder but I don't know if I did it right since the buttons continue to not work. At first when I tried soldering I formed a big clump of metal but then evenly separated them to their location. I don't know if that may have been the problem. I also did not use liquid flux. Help me out please.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hey mate,
It depends on how well you soldered. If you cold soldered, a proper connection is not being made. If you bridged the connection (which it sounds like you may have). If you could provide a picture, this would help a lot.
Update
Hey Miguel,
A cold solder is when the two points you are attempting to solder together are not being heated up enough - only the metal that you melted from your solder got hot enough to melt, and the point you are trying to solder to did not melt. This will result in a very poor connection and generally, it not working. If you could post a picture, this would help.
这个答案有帮助吗?
得分 2
1条评论:
What do you mean by cold soldering?
完成的
添加一条评论
添加你的答案
Miguel Salazar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 556
