跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Why is the screen white after a new LCD replacement?
Hello,
So I bought an iPhone from this guy, a really bad choice because the phone was old. But after a few months it started having lines (blue and white) up and down the screen. The phone can still operate if you remember where everything is, but obviously you can't see the screen. So someone told me to replace the LCD, which i did. I did everything without any issues, following a video tutorial. After installing I turned the phone on and it showed the apple, then it went to the white screen. I tried reseting it and what not still the same issue. Also, when you plug it in to the charger you can see the screen, once you slide the unlock button it goes back to white and the only way to get rid of it is to put it to sleep and then turn it back on again.
I would really appreciate any feedback on this!
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
I have already done a hard reset. and nothing changed, the screen still flickers then goes white
完成的
添加一条评论
2个答案
已选择的解决方案
Have a read of THIS thread I may assist you
这个答案有帮助吗?
得分 1
添加一条评论
try a hard reset
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lera 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 121
